If you were to use the "Advanced Search" feature of these forums and a few keywords, I believe you will find there have been many past, similar inquiries with resulting threads/opinions/references concerning flow velocity limitations of plastic pipes. If you vary the keywords some, more past discussions will probably pop up. Also, I believe there have been many past discussions on many Eng-Tips, as well as extensively on NACE forum lists, of various "SS" pipes and e.g. seawater exposures. From past recollections, I believe at least many authorities appear concerned in general about high velocities and plastic pressure pipes (I suspect primarily due to surge/fatigue considerations and possibly other), as well as the effects of chlorides, external soils and/or MIC etc. on at least some "SS". I think whether or not you will have the problems they worry about in your application(s) may have one of those "it depends" type answers (maybe depending on significantly more information than you've provided here).
