I have an electronics box coated with a thick layer of a poorly-conductive substance. An external heater applies a flux Q'' to the box. I need to obtain the temperature rise as a function of time knowing the specific heats of the substance and box, the thermal conductivities of the substance and box, and the densities of the substance and box. The electronics box has an internal heat generation of Q. There is no way of cooling the box. Once it reaches a certain time it has accomplished its mission and is sacrificial. It is safe to assume the box is of uniform temperature because it has a lot of aluminum in it. I need to determine the temperature at a given time t. Any takers want to tackle this one? The heat flux is not trivial. It's 11,500W/m2.
Bruce aka Tunalover
Bruce aka Tunalover
