purpose of wear ring in impeller and casing in suction side of pump
pradeep4u
67
Dear All
what is the purpose of wear ring in impeller and casing in suction side.
Pradeep
Dear littleinch
I know this but apart from this I wanted to know how does increased wear ring gap affects pump bearing life. Does it also acts as a bearing.
Pradeep
There are numerous other things that effect bearing before considering wear ring clearance. As for the second question - NO.
Any close clearance bushing or wear ring with a pressure differential across it will provide some support for the rotor. Internet search for Lomakin Effect.
Johnny Pellin
Thanks to all for your precious inputs. I want to ask one more question regarding to boiler feed pump journal bearing and bearing top cover interference. We use HDB 125/9 KSB make pump. it has 9 stages. In journal bearing at DE AND NDE side we keep interference of 0.06mm between bearing and bearing top cover. I just want to ask why inteference is kept. Please give your valuable suggestions
Pradeep
Seems you have opened a second post to address the last question.
Dear All
Thanks for your valuable guidance.
Regard
Pradeep
