Hi
In General, Lantern Ring are widely used in applications where outside lubrication is necessary in order to keep packing lubricated, cool and flushed of abrasives and chemicals. it is used to increase the life of compression packing, resulting in less maintenance and downtime over the life of the equipment.
Mostly lantern ring is used in pump applications. but for valve application, it is used when we are using the environmental packing for splitting the two packing sets to provide the better performance and sealing, also lubricating the packing.
lantern ring will be in any form of material such as steel, PTFE etc. depends on application.
Thanks...
Dinu...
There are no secrets to success. It is the result of preparation, hard work, and learning from failure.
