[blue]Laser28[/blue]:
I think we're on the same page; perhaps you can understand why I took issue with your first post by re-reading it. Your first post implied that vapor barriers are ineffective, and thus not needed. Your second post seems to clear up your position on this point -
I'm not surprised that the presence of a vapor barrier correlated with slab curling; I would have expected that anyway. Curling is likely to occur when the top surface of the slab dries too quickly causing the top surface to shrink before the slab has sufficient strength to resist these forces. You would get less overall difference in drying (between the top and bottom of the slab) with a sand layer in contact with the lower surface of the concrete slab as it cures. This would probably result in both sides of the slab drying at nearly the same rate. But the presence of curling is not an indictment of vapor barriers, nor is it an excuse to eliminate them. It does point to the need for better concrete mixes and curing techniques -
![[soapbox] [soapbox] [soapbox]](/data/assets/smilies/soapbox.gif)
First, let me state that I have not read the National Research Council in Canada report that you have referenced. But I suspect that others in this forum have. (Hey, [blue]BigH[/blue] or [blue]jheidt2543[/blue] - do either of you have a copy?) The following comments may or may not apply to the referenced NRCC study -
In my view, it is very important to read all technical journals with something of a "jaundiced eye." Many writers get so wrapped up in the designing, collecting and presenting of technical data that the analysis gets rushed too much - and they don't take the time to really consider the data in a "big picture" context, so the
really obvious answer is overlooked. I know of quite a few examples of this in the geotechnical engineering literature; and I'm willing to bet a cold pitcher of Bass Ale that the problem isn't limited to the geotechnical engineering community.
It's the reader's duty to evaluate the statements and claims made in any learned journal and decide for his/her self whether they are reasoned and appropriate. Remember that we all put our pants on one leg at a time...no one (or group) is infallible.
If you want to continue this discussion, why not start a new thread? We're a bit off-topic...
Please see FAQ731-376 for great suggestions on how to make the best use of Eng-Tips Fora.
