punching shear with only top reinforcement 1
Bammer25
154
Maybe a dumb question for some, but I am checking punching shear in a slab on grade. I intend to only have top reinforcing, so am I restricted to only using the depth down to rebar for punching shear check? that is going to seriously constrain me. I have 25Kip wheel loads and a 6" slab.
I know i can lower the rebar down to where i need it for punching shear, but id like to keep it up near the top for moment.
Good on you for identifying the rebar placement issue. I'd switch to the plain concrete punching provisions. The stuff below is taken from ACI 318-19
thanks. i did not think to do that. odd thing is i got a higher capacity than i would have with the rebar at the bottom of the section...
With this section, I think you're supposed to subtract 2" from the "footing" depth because it's cast against soil, not that this code applies.
ACI 318-14 1.4.7
This Code does not apply to design and construction of slabs-on-ground...
Now that the SOG is probably a spread footing, I'd be tempted to say that code does apply.
If it is a 25 kip wheel load, then your 6" slab might not be appropriate. 25,000# is pushing it. Check with some of the pavement design references. The slab near the joints/edges will be a problem if you have a load which can be located anywhere.
If this is a post load with a defined location, then you might be able to add a thick base plate and some grout to activate more of the slab perimeter (and design it per ACI 318).
Bending is not an issue and punching is fine. It’s in a contaminated area so we cant dig at all. Backfill with crushed stone, compact, pour.
Since we are on the subject, how do you guys normally check your structural slabs? I usually just model it in STAAD and take comservative moments with 12x12” plate elements.
I feel that TR34 is the state of the art for this nowadays.
The method in this article is quick but some question its validity: Link
