I need to install a safe in a friend's house on a metal structure so the safe will sit about 2 ft above floor level.
I wil design the metal structure, but I need to know whether I can put the thing on 4 legs, or if I need to have a square frame at the bottom as well to spread out the load.
Problem is that if I need a frame at the bottom, it'll need to be field welded partly (exisiting pipes and electricity in the way).
Weight is around 600 kg (1300 lbs).
What data should I prepare before consulting an engineer that does this kind of work?
I know the thickness of the slab and the grade of concrete. I do not know what's below. Should I even bother to ask in this case, and go directly to a full frame, with the problems that go with this solution (welding inside ahouse, near piping and electricity)?
If I could put the whole thing on 4 legs, that would make the install mush simpler.
please guide me on how to proceed...
