ivanhoe374
Chemical
We have a reverse osmosis system that has a small feed pump which then feeds the larger high presu pump. The sum of the concentrate and permeate from the RO is 1.7m3/hr so the feed pump should be running at the same rate. According to the curve this should correspond to a pressure of 30m. However the discharge pressure is only 20m, and this is resulting in the RO cutting out as it has a low pressure switch set at 20m (which cant be changed).
All that is between the pump discharge and the RO is a few elbows, a check valve and about 1.5m of pipe (20mm).
Any reason why this pump isnt running on the curve? besides the obvious reasons of a line blockage, insuffuciet power supply?
I wasnt sure if having the RO high pressure pump in the same line in series could cause this? wouldnt it just add to the pressure fed from the feed pump?
