I am interested to know/understand the standard control configuration for 2 pumps in series.
What i have seen is the first pump (fed from tank) has discharge valve controlled by tank level.
The second pump has its discharge valve controlled by suction pressure of the second pump.
Is it possible to control the system with only the first valve? (Someone said to me that it can't be done that way becuase the flow of the second pump wont match the first pump flow, and could result in draining the inbetween pipe- resulting in vacuum).
Of course part of the answer is that the suction pressure is controlled to prevent caviation in the second pump.
Any advice/comments?
jon
jon
