pumps design
vjr0512
IN
We have been proposed with VS4 type pump for sump pump ( effluents + oil application in Hazardous zone application - ZOne 2) with 3 and 4 shaft construction with intermediate bush bearings + fresh water lubrication( for a pump length of 3500 mm long) . Earlier when it was discussed with the EPCC ,for the design of submersible pumps, it was said that there are no manufacturers to provide submersible pumps with motors suitable for Hazardous zone applications.
Thanks to provide whether there are any manufacturers for Submersible pumps with motors for Hazardous zone applications. For manufacturing VS4 type pumps, is it a manufacturing difficulty in providing in single shaft construction with intermediate bush bearings + fresh water lubrication?
Depending of pump duty, material being pumped etc - there are a number of electric submersible pump manufacturers. Google flame-proof electric submersible pumps or something similr.
"when it was discussed with the EPCC " - well they would say that wouldn't they??
Elec submersibles for hazardous fluids are almost certainly more expensive, but eliminate a lot of the issues involved with a VS4 type pump.
Yes, it is possible to furnish submersibles with hazardous classification motors.
Submersibles tend to be less expensive on initial cost, but have higher maintenance costs. In the long term, submersibles will be more expensive.
Check with a VS4 pump manufacturer regarding the possible manufacturing problems. Don't believe it is a problem:
bimr is correct - hazardous area submersibles are available and lineshaft driven pumps properly selected of good quality and depending on installation / maintenance and materials of selection can give long life.
Depending on the installation I don't necessarily agree that elect. submersibles will be more expensive long term -- but there are many variables in pump installations.
As stated, ATEX/hazardous area submersible pumps are common in the marketplace (subject to material requirements of course) and would tend to be more expensive long term (in my opinion).
We have made vertical pumps to 5 metres long with intermediate bearings and either product or clean water flush, as well as manufacturing the option of cantilever shaft pumps - bit more expensive, but sometimes needs must...
Ash Fenn
