AdamMurray
Currently have a client who requires a stored water supply. Typically would recommend vertical turbine fire pump and cistern. However, the architect would like to have the stored water supply installed adjacent to the basement (burried underground), and have the fire pump installed in the basement.
I have seen this type of installation in some older buildings, using a horizontal split case pump. Is anyone familiar with this type of set up.....would you be concerned with zero suction or priming of the pump?
Any information would be apreciated.
Adam
Adam
