rocketscientist
Chemical
A question came up today regarding pressure drop calculations around a centrifugal pump. One gentlemen says that there is no need to add a K factor (K = 1, typically)for a pump discharge. He says that the pump supplier accounts for the pressure drops at the inlet and outlet of a pump.
What do you say? Are you supposed to add entrance and exit effects in a hydraulic calculation with a pump or does the pump curve already account for these losses?
