sowhatso
- May 9, 2007
- 99
KSB pumps were installed and will be realigned , the pumps are Multitec Horizontal Booster pumps , at the O&M manual it was indicated that : "The radial and axial deviation between th two coupling halves must not to exceed 0.1mm".
From your experience of pumps alignment can you tell me what are the best tools that you recommend for aligning the pumps and what is the accuracy needed for the tools ??
Does it need to be lazer alignment tools ??
any inputs about the KSB pumps alignment are highly appreciated ..
