Pumping silicon oil
NESLABman
GB
Anyone got much experience of silicon oils as heat transfer fluids.
I am working on some systems using positive displacement pumps to move approx. 12 lpm of silicon oil (Sil 180) at 5.5bar. The fluid is anywhere between -30°C & + 150°C.
The pump manufacturer insists the oils are compatible, but they continue to leak.
I'm guessing the temperature range of the fluid may be the issue, causing excessive expansion & contraction.
Anyone know of any pumps that may do the job?
The NESLAB specialists in the UK
Check the websites of freeze dryer manufacturers like BOC Edwards, Usifroid, Christ and VirTis etc. Silicon oil is used as a heat transfer medium in freeze dryers and the temperature range is +30C to -85C generally and can be higher during sterilization cycle. Have you thought of a buffer vessel?
