EmmanuelTop
Chemical
I am looking to find a reliable solution for pumping mixture of water and gas condensate that contains about 80% aromatic components (Benzene, Toluene, Ethylbenzene, Xylene). Suction temperature is 50 degC (~120 degF) and pressure is close to atmospheric. Discharge pressure variable - often close to atmospheric but sometimes up to 4 bar abs hence gravity flow is not an option. Capacity is about 1 m3/hr (4.4 GPM). The service in question is TEG regenerator overhead drum.
Due to possibility of running dry, the designer opted initially for peristaltic pump. However the pump rubber tubes were failing quite frequently due to incompatibility of tube material with Aromatics/BTEX, and after being replaced with Viton tubes they failed even faster (could anybody throw a hint why? - chemical resistance charts are saying something else). Viton tubes failed within just 48 hours.
Due to variable discharge pressure and possibility of running dry, centrifugal pump is not considered as an option. Someone came up with an idea to employ Eccentric Disc Pump (see e.g. but the concern here are O-rings. I guess we could use perfluoroelastomers but nobody can say for sure (especially after seeing Viton tubes fail so fast and they were supposed to have solid resistance to BTEX).
Fugitive emissions are not a concern here.
Anyone with hands-on experience with Benzene pumping?
Dejan IVANOVIC
Process Engineer, MSChE
Dejan IVANOVIC
