Good Day All,
I have a centrifugal pump that is operated at times with a closed discharge due to the application. In order to ensure that there is a continuous flow at all times through the pump, I want to install a bypass line on the discharge header that would recirculate flow back to the pump suction in the above condition.
I have been told that a Yarway Automatic Control Valve which senses flow can be used to achieve the above. The valve would recirculate the minimum flow required by the pump. Do anyone have experience with this control valve in a similar system?
