Dear All,
I am seeking your experience on the reference quote in API 610 advising on:
- the sizing basis for the suction and discharge pump nozzles, in some instances I observed that inlet piping size can be for example 24'' while vendor advising suction nozzle of 12'' .. is this odd? and what is the physical phenomena behind determining the size of the suction and discharge nozzles? momentum?? suction energy?
- The minimum straight length upstream pump nozzle to ensure unseparated and uniform distribution to the impeller eye, is 4 D a typical value and do we decide to increase it?
- When to decide whether the pump shall have top-top or side -top arrangement, which section in API 610 advising on a preliminary criteria for the same.
