Working on a project to install two pipelines, freshwater and produced water, going 10 miles from one atmospheric pit to another. They don't mix if course. It has been determined that a booster pump station must be installed at a midpoint which also happens to be at the bottom of a hill/draw/whatever you'd call it. This is due to access. There's about 100' of height before the booster pumps, then about, oh, 90' of height after the pumps. I did my best to convince folks that we should put the station at the top of the other hill; seemed to make sense to me, but employee access (there's no easily accessible road to the other location) was more important.
My concern, not having done any of these in this type of location, is the velocity and momentum of the water coming entering the pumps. Could the water somehow rush ahead, possibly vaporize, cause cavitation, etc. issues at the pumps? If the pipe does, in fact, stay liquid full, does the speed of the pump have a factor at all with reference to boosting the pressure? Is this no different from any other pump install, with the exception of having more NPSH available? I feel like I'm overthinking this but I just believe, common sense (I hope), that having a gravity fed pump like this has many more considerations than just the discharge pressure to get the flow back up the hill and to it's destination. I'm not confident that the engineering company that did the hydraulic assessment did much more than just determine the pressure required at the bottom of that hill to get the water to its destination.
I am aware that I would need to preform a surge study to determine the pressure surge at the pump station should things get shut down suddenly, or blocked in.
The pipeline is about 10 miles long. Flow rate is around 35,000 bbld through a 10" poly line, SDR9. We'd like to keep the pressure below 200 psig; it's a comfort level thing for the guys I suppose. I need to refresh myself on the required flow so that might not be the right number. Just getting back into the project...
I'd appreciate y'all's advice on considerations, things to look out for and ask, etc. The project was started by me at which time I confirmed the design basis and routing of the pipelines, another engineer took it over and nudged it along a bit and had the hydraulic study, and now I'm taking it back over. I'm going to re-engage the engineering company but also get some pump skid fabricators and the pump vendors themselves involved to get their thoughts on how this seems to be coming together.
Thanks for your help and advice!
