Khansahib
Chemical
- Nov 24, 2006
- 62
I have been asked to look for a suitable pump that can pump liquid from two phase separator to another platform. The production separator will be operating at 40 PSIG whereas the pump discharge reuirement is 140 psig. The amount of liquid is around 30,000 blpd (oil+water). Neither electricity nor high pressure gas/air is available on the platform however, on recommendations either can be provided. There a lift gas line passing close by which is operating at 300 psig, it can be tapped for provision of gas to run pump otherwise electric cable (2.5 km) is to be laid down from another platform. To my mind a reciprocating pump can be best suited as the liquid will be a mixture of oil and water, the viscosity and sp. gravity will keep on changing minute by minute. However, I am also thinking a vertical pump due to space constraints on the platform. I have reservation on opting the gas option to run the pumps because of gland leakage and disposing it. Your valuable suggestion and recommendations shall be appreciated.
