A Client has asked for solutions to a corrosion problem they are having on an injection pump. Below are the process parameters:
- Operating temperature is 54 degC
- Sour water service
- Chloride levels are in the 1000ppm order (definitely below 100,000pm) but not known exactly
- MOC of casing and impeller is SDSS
The client reported corrosion even when using SDSS, and require corrosion resistant alternatives. To my knowledge, SDSS can withstand pitting corrosion in high chloride services (not sure about the ppm limit) up to around 35 degC.
Any suggestions? Would Hastelloy fare better here?
Thanks,
Maen
Thanks,
Maen
