Jordannn
Chemical
- Apr 1, 2017
- 2
Hi everyone,
I am new to the industry and have a quick question. I have 3 sets of pump data.
RPM Discharge Pressure(PSI) Flow Rate(GPM)
1570 370 300
1280 250 250
1020 150 200
Background information: Pumping water at 25 DEGC and with the discharge pressure listed above and corresponding flow rate through a tube bundles, the outlet pressure is atmospheric pressure.
I have built a hydraulic model, but my question is with the same system (same number of elbows, bends, pipe lengths, etc.), why the last two sets of data will give an outlet pressure less than atmospheric pressure?
Thank you,
Jordan
1570 370 300
1280 250 250
1020 150 200
Thank you,
Jordan
