I saw a in-line centrifugal pump ,but it didn't have a baseplate ,from the outline drawings I only can see there is a pipe flange spool base match ANSI 125lbs flange dimensions.
my question is that this pipe flange support is underneath the pump to support the pump or underneath the sunction and discharge pipe to support the flange ????
also I want to know how many pipe flange support is for one in-line pump ?
