I am trying to find the minimum flow rate for a set of Sour Water Pumps that have been in existence for some time in the refinery. I have two pump curves. One is the performance curve from the vendor which shows various impeller sizes, hp, etc.. and the second is a characteristic / test curve for the current impeller size of the pump, head and efficiency. Readings for the same capacity from both curves yields different avail. head readings. The test curve gives less head than the performance curve at the same capacity. Which curve should I be using??
