I have a bunch of kW data (hour by hour)used by some pumps that are used for pumping water from one area to another. They are rather high volume pumps...around 3000 gpm each. What I want to do is take all the kW data and use that to estimate a flow rate for each pump during each hour to get a total of how much water has flowed. I have never done one of these types of calculations. I have some pump curves. Would the following steps be a correct way to go about it?
1. Determine total head, which is 236 ft.
a. I have estimated the friction head to be around 2 ft using a friction head calculator on the internet (10,000 ft of 30" ID steel pipe)
b. Water level is raised by 234 ft.
2. Using the bowl head vs. flow curve, find the flow rate.
I don't know where to go from here though and it seems as though I am missing something since from what I have assumed, the flow rate does not depend on power input. I presume I will have to multiply the kW number I have by some efficiency, but with the efficiency vs. flow curve, I need a flow to find efficiency.
I also have a curve for BHP vs flow. Can someone point me in the right direction?
