curtis2004
- Jan 8, 2010
- 301
Hi Everyone,
I'm designing piping system for thermal fluid with design pressure 150 psi @ 550 F. I have a pump in this Hot Oil system ordered from Germany and I've got the following flange specification:
Pump Standard: EN733
Suction nominal dia.: NPS 6
Suction nominal pressure: CL 125
Suction Flange dimension according to standard: EN1092-2
Suction flange drilled according to standard: ASME B16.1
I have question: What flange do I need to buy for my piping to connect this pump's flange? Will A105N 6" x 150# with Flat Face (removed raised face) work?
The most of the system welded construction and I do have control valves with A105N 6" x 300# RF flanged connections.
Curtis
Curtis
