In the following thread: thread407-166705 the following quotes state that efficiency stays relatively unchanged at different rpms
"This is what Sulzer has to say on the subject of efficiency as function of speed of rotation:
Quote:
Where the system curve derives wholly or mainly from friction losses, speed control is best, because pump efficiency then remains prctically constant...With small speed changes (up to 10%) efficiency remains virtually unchanged. With bigger speed changes the velocity in the channel alters and with it the Reynolds number. The efficiency factors must be downgraded at lower speeds and upgraded at higher ones.
Sam Yedidiah:
Quote:
A comparison between the data calculated from tests performed at 1740 RPM and the actual data from the test at 3550 RPM leads to the following conclusions:
1. As far as the QH curves are concerned, the data calculated from tests at one speed seem to be reasonably accurate for the other speed. However, at the lower speed, the QH curve seems to be able to go out to a greater Q/Qd ratio than at the higher speed, possibly owing to cavitation in the casing throat.
2. The efficiency curves show certain differences, but they rarely seem to exceed ±3%.
3. The NPSH requirements at 3550 RPM, calculated from the results at 1740 RPM, vary considerably from the NPSH requirements determined from the tests performed at 3550 RPM. In terms of suction specific speed, the pump seems to have a different suction specific speed at each of the two tested operating speeds."
Yet in the following technical paper on page 4 when removing a control valve and installing a VFD to achieve the same flow rate but at a lower head, the technical paper says efficiency declines an appreciable amount.
Does anyone know where I could find an equation to estimate how efficiency would change with changes in RPM if not given on the pump curve? Thank you,
-Tim
Sam Yedidiah:
-Tim
