Pump design requirements in Drilling.
The pumps in the drilling industry are missing check valves on the outlet from the centrifugal & reciprocating pumps; Why are there no check valves in the drilling process? Are not Mud & check valves a good combination?
Additionally what are the filter requirements around pumps which are pumping mud? It is suggested that duplex filters are required. These pumps are pumping mud not hydraulic or lubrication fluid which then I would insist on duplex filters. The pumps in question are stopped & started at irregular intervals. Are Duplex filters necessary and when would one install Duplex filters?
Is there an industry norm which I can use for the basis of the design around pumps? Any feedback information would be beneficial.
Cheers
Cheers
