Scotsinst
Petroleum
- Feb 7, 2003
- 78
Yarway (Tyco) and others make an automatic recirculation valve (ARC) for automatic pump spillback when the flow falls to the pump minimum required spillback rate.
I am reluctant to specify this type of spillback because I have had no experience with it. Some of our systems require long term controlled spillback, so on-off control is not acceptable.
Is there anyone in who can share good or bad experience with this equipment?
Anyone using an ARC on a high head pump(>2000 psig discharge pressure (140 kg/cm2(g))?
