fittings are often included in the unit price. Again, we need a lot more information.
Do you want the price in dollars or Euros?
Do you want restrained or bell and spigot joints on your pipe?
You say 240 kPa - I assume that is kilopascals, that equates to just 35 psi. Is this a low pressure irrigation pipe? Or is it municipal potable water?
How many gpm for your pump station? Or do you just want the one pump? Vertical turbine pump? Just 35 psi? Do you need the driver also? How about MCC, switchgear, check valves, pressure gages, flow meter, concrete pad, roof and/or walls, duplex or triplex pump, etc.
