Pull off adhesion test : choice and influence of the diameter of the dolly
kinkin28
Materials
FR
I am a french material engineer.
I want to carry out pull out tests on coatings applied on steel surface and concrete surface.
So my questions are :
- Do you know why the diameter of the dolly is different between concrete surface (50 mm) and steel surface (20 mm or < 20 mm)?
- Is there an influence of the diameter of the dolly on pull out test results ?
Thanks for your answers
