I have a PTFE (graphite filled) seal that I am testing running on a 2" shaft @ 500 RPM, 500 Psi. Test fluid is water at 50°C. It is grease lubricated. We are measuring temperature near the seal of 150°C which seems ridiculously high to me. Are you surprised by the temperature? I would never have guessed that a PTFE seal could generate that much temperature on its own. At this temperature you can't expect PTFE to perform a sealing application for long.
Any comments?
Any comments?
