Gents,
We are planning to select a PTFE single diapfragm metring pump to pump gasoline. The pump will opertate at 50 meters diff. head and 1.2 m3/h flow. It pumps from the tank buttom and the stream contains solid particles, does this pump type fit the requirmentrs? Does PTFE handles such a process? the vendor (LEWA) guarantees 20,000 hours of opeartins as i questioned the realibilty of the diaphrgm. The NPSHA is very low (0.4 meters), can you pls. advice
upm
upm
