PSV/rupture disc combination 1
TD2K
Chemical
Jan 11, 2002
2,629
I have a PSV with an inlet rupture disc. The derated PSV capacity using the certified combination factor is greater than my required capacity so I'm okay there.
My question is with respect to the inlet 3% line loss guideline per API 520. The conservative approach is to calculate the inlet line losses using the PSV's capacity flow rate (without the rupture disc rerate factor) and include the effect of the rupture disc in the piping losses (for this disc, the vendor has certified resistance coefficient) as just another component. If I'm below 3%, I'm okay.
Alternatively, I was thinking whether the rupture disc/PSV should be viewed as a combined device given the derating factor and the inlet line losses are calculated using the PSV's derated capacity and without the rupture disc being considered as a piping component.
What have other people seen/done?
I found the answer in API 520, part 2. The effect of the rupture disc is to be included with the inlet piping losses and that total is subject to the 3% inlet line loss limitation.
Sometime back I downloaded two good papers from Fike but unable to locate those from their website now. One of the papers deals with combinations of rupture disc and safety valve. Let me know if you are interested to have a look at them.
Sure, do you still have my email address Quark?
Yup, for a life time. Just give me a week as presently I am spending free time due to a change in job.
