maintennance
A 53B seal flush system is provided with a PSV . I have come across a TRV in the cooling water system. But what is the technical reason for having a PSV in the barrier side ?
Similarly for the 53B seal system , whether the accumulator and the cooler has to be designed for the process liquid side pressure ( MAWP of the Pump) and temperature? If so , if the process liquid temp is 200 Deg C, whether the bladder material to be suitably selected? Even if the seal leaks, the barrier fluid only has to go inside the Pump. In one of the document it has been designed for the process fluid temperature and the MAWP of the Pump. Thanks to clarify
