PSD Analysis w/ Patran
ChrisDD
New member
Mar 4, 2004
1
I just try to do a PSD analsyis with MSC Patran (2003) for a vibration test of aerospace equipment. I already did a modal analysis for the test setup to determine the Eigenfrequencies (which was no problem)
Now I have a defined frequency/level (Grms) curve for X, Y and Z axis.
How can I define this in Patran ???
Thanks a lot !
Christian (Dresden, Germany)
Christian;
That depends on which solver code you are using. If you are using Nastran, you can create the PSD curves using fields "frequency dependent, non-spatial". If you are using Abaqus, you can define them directly during the step creation process under the analysis menu.
Cheers.
Ahmet Becene, Ph.D.
USA
