Hi guys! New here. I've been working with the modeling of a potable water network in which I need to put several PRV because the topography is very steep and the pressures are above what I require by norms in ym country. The problem I'm having is that most of those valves are closing when I run the model, so it leaves some pipes without flow. I've been moving the valves around to find a way to make them work together and stop them from closing but I can't seem to find a solution. I'll appreciate any input you can give me
