rockman7892
- Apr 7, 2008
- 1,178
I was looking for some good references for protection considerations during the startup of a Gas Turbine generator when the generator is being driven as a motor by an LCI drive.
Since the generator will in essence be a synchronous motor during the starting phase I'm thinking some of the principles of synchronous motor protection apply during the starting process.
From some of the information I have seen, some consideration must be given to the differential protection since the LCI may fall within the differential zone and this may cause mis-operation of the differential element. Is it recommended to have some protection elements that have two settings groups for both starting and normal conditions?
It also appears that some of the most critical settings during startup are V/Hz, Overexcitation, and Overcurrent, along with phase and ground fault protection.
I'm not really familiar with LCI's and their controllers but I'm assuming that the units have a controller or protective device that provides certain protection elements of the LCI and generator during the starting process. I would also think that the excitation controller would have similar protection functions.
Thanks for the help!
