takedownca
- Mar 2, 2007
- 145
I need to model a 2"-11.5 NPT internal thread. I believe I have all the dimensions I need, but I have a question about the nominal diameter. Since pipe thread is conical, it doesn't really have a set diameter. So if the above thread is spec'd to have a 2.375" nominal diameter, what does this number refer to? For regular straight thread, the nominal diameter is slightly larger than the major diameter. If this applies to pipe thread then the initial major diameter is something slightly less than 2.357", but I'm not sure of this. I know if I'm off by a little bit the thread will still be functional, but I'd like to be as close to the ASME B1.20.1 standard as possible.
