frag68:
You really have not explained your problem in detail. I assume that you are talking about the pressure in an engine cylinder using propane fuel. Is that correct?
I also assume that by a "fixed volume", you meant the volume of the cylinder. Is that correct?
If both of my assumptions are correct:
--You must first know the amount of propane and of air that is admitted into the cylinder before ignition. Knowing those amounts, you could calculate the adiabatic flame temperature and the volume of combustion gases (i.e., carbon dioxide, water vapor, nitrogen, and oxygen). The nitrogen enters with the combustion air, and the combustion gases will include oxygen if your engine uses excess combustion air over and above the required stoichiometric amount.
--Knowing the temperature and the volume of combustion gases contained in the fixed cylinder volume, you could then use the ideal gas law (PV=nRT) to calculate a first estimate of the resultant pressure. If that pressure is fairly high (which I assume that it is), then you might want to calculate the compressibility factor (Z) of the combustion gas mixture and recalculate the pressure using PV=ZnRT.
I note that you are a mechanical engineer. The above methodology is fairly complicated and I would advise you to seek help from an experienced chemical engineer if you are unfamiliar with the above described calculations. Or perhaps an experienced automotive design engineer could help you.
Milton Beychok
(Visit me at www.air-dispersion.com)
