Came across a couple interesting experiments. One particular thing caught my interest:
________________________
Full experiment here:
Also mxiture tests with LPG:
The engine I have has a 8.5:1 CR. Unthrottled (1atm in the manifold), I should have a in cylinder pressure of about 2Mpa, and a temp of about 414C ATDC. According to the experiment, it should still be ignitable at over a 2 lamdba AFR, probably more like 2.5 or more if the gain in lean ignitability up to 200C (as high as the experiment goes) is any indication.
BTW, the fuel system is being converted to a constant proportional injection of propane (computer controlled proportional control valve), just like in the above experiments. After reading the inlet mixing tests, I'll probably use the exact method of injection ("j" jet) that they found to work so well.
Previously, when the motor was a normal throttled gasoline motor, in order to maintain a idle speed of about 1000RPM, the throttle was adjusted get a manifold pressure of ~60kpa (60% of 1atm), with a stoich mixture of gasoline.
So am I right to think that if I took the throttle out, and set it to a mix of about 1.66, it should maintain at or near my previous idle of 1000RPM? Or the removal of the pumping losses of the throttle mean I'll need to run it even leaner, to keep the power low enough to maintain a idle speed? If the required lean mixture is still ignitable, no problem right?
So it would kind of be like a diesel in so ways (no throttle, engine power/speed controlled by fuel), but different (still uses timed spark ignition).
Before anyone mentions it, it's never been tried with gasoline because this approach REQUIRES a gaseous fuel, a liquid fuel has far lower lean burn limits. That's mentioned here, in another great article:
Any big holes in this theory I'm missing?
