sodengineer
Hi All
I'm from the Civil side of the forum, but I'm working on a project far from civilization and it requires solar power. I'm NOT here for the solar power question but for a heat quesiton. This system will push electricity into a battery. I need to keep the battery from freezing through the winter. This will be an inexpensive (I hope) automotive battery. The problem is that it will be located at 8500 ft in Wyoming and will be inaccessable from November to June. I want to keep the battery from freezing in the winter. I will have it in an insulated box, but I'm still concerned about freezing. If I put a small propane heater (I'm thinking of something that would be essentially a pilot light that would run all winter, or even something as simple as a "bernz o matic" torch connected to a 5 or 10 gallon tank.
Is something like this doable?
Is there a specific "heating box" made for batteries and I can avoid this whole cobb together process?
How much propane (gallons) would I need to run something like this?
Mike
Mike
