We need to proofroll a heavy haul road using a minimum simulated wheel loading of 90 psi. The tandem axle dump truck we are planning on using will have a tire pressure of 110 psi. The issue is, what do you base the loading on; the 110 psi tire pressure or the weight of the load divided over the contact area of each tire? The measured contact area is very subjective based on the squatting of the tires under load. The text books I have studied provide formulas for defining the tires contact area, however, it all comes back to the tire pressure (110 psi). If this is the case, what is the rational for proofrolling with a fully loaded tandem axle dump truck, if the tire pressure is what governs.
Sorry for the long winded scenario. Looking for some opinions.
Bagger
Bagger
