Promting in vba / api in solidworks ?
jlivingstonsg
Computer
Aug 14, 2015
4
Hello.
There is a great youtube video on how to use VBA in AutoCad.
Can someone tell me how to do the same in SolidWorks?
When I run it it prompts me to insert two values, length and width, then I get a square in AutoCad.
Can it be done in SolidWorks?
When I do the same in SolidWorks it does not prompt or draw anything.
Up left in Autocad there is something called "ThisDrawing".
That is missing in SolidWorks.
What do I change to get it to work in SolidWorks?
Regards Magnus
Anna already gave you a hint.
SolidWorks is capable but probably not the way you expect it to behave. You should not expect two different products look and feel exactly the same.
Is it not possible to create a drawing by activating a "UserForm" in Solidworks as in Autocad in the video?
Why do you need length and width to get a square?
