Projection view links catia
vjxzy
Automotive
IN
thread560-158226
Hi i need a solution for a problem.
Problem - when i copy front view and its Projection view (Top, bottom, sides)from sheet1 and paste it to sheet 2 links between front and projection views will be lost is there any option to link the projection views to front view so that when i move the front view all the projections vies will also move with it.
here a small code that links the positions of each view :
1.front view must be active
2.align manually the views if they are disaligned
Code:
Sub CATMain()
'***            Macro de réalignement des vues           ***
'***         V00 du 04/02/2016 de Marc Litzler           ***
'***         Activer la vue de face                      ***
'***     Repositionner les vues à l'aide d'éléments      ***
'***               Lancer la macro                       ***
 ' Vérifie si le document actif est un CATDrawing
Dim MonDessin As Document
On Error Resume Next
 Set MonDessin = CATIA.ActiveDocument
   If (Err.Number <> 0) Then
      MsgBox ("Un CATDrawing doit être actif")
      Exit Sub
   End If
   On Error GoTo 0
  If (InStr(MonDessin.Name, ".CATDrawing")) = 0 Then
   MsgBox ("La fenêtre active doit être un CATDrawing")
   Exit Sub
 End If
Set sheets1 = MonDessin.Sheets
Set s1 = sheets1.ActiveSheet
Set vcoll = s1.Views
Set v1 = vcoll.ActiveView
 nbview = vcoll.Count
For i = 1 To nbview
    If (vcoll.Item(i).Name <> v1.Name And vcoll.Item(i).Name <> "Main View" And vcoll.Item(i).Name <> "Background View") Then
        If MsgBox("Align " & vcoll.Item(i).Name & " with " & v1.Name, vbYesNo) = vbYes Then
            vcoll.Item(i).ReferenceView = v1
            vcoll.Item(i).AlignedWithReferenceView
        End If
    End If
Next i
End Sub
Marc
thanks, Marc I will check this out.
THOUSAND Thanks, Marc but I still need to learn how this is working can u explain [thumbsup2][glasses]
