projected geometry
stennis
can someone explain to me what this command is and why it is used?
Have you tried pressing F1 and reading "about project geometry"?
It's used to "project geometry" (like a line or circle/hole,etc..) from other features/parts onto your current sketch plane.
I use it most often to either "reuse" existing part geometry in a sketch so that I don't have to redefine the dimensional and constraint relationships that I have already fully defined in other sketches, or to "link" sketch geometry to other previously defined features to create a direct relationship between an existing part feature.
David
It is used to define references for a sketch to be constrained to. or make a sketch dependent on any previous geometry.
