Hi All,
First post, so go easy on me!
I have a part with six nominally co-planar mounting bosses over a total area of approximately 450mm x 450mm.
I have received feedback from the supplier that they can hold the "flatness" of these bosses (their terminology, not mine) to ±0.05mm per 100 x 100mm area. Thus they propose an overall "flatness" tolerance of ±0.2mm for the faces of these bosses. This (just about) acceptable to us, so we would like to capture this on our piece part drawing.
I would prefer to use Profile of a Surface in place of a flatness tolerance for a couple of reasons; the ability to control position (using a basic dimension) within the same tolerance and also, most importantly, the implicit inclusion of co-planarity provided by Profile of a Surface (Sec. 8.4.1.1 of ASME Y14.5)
I am proposing setting a datum plane (Z) to be co-planar with all six boss faces and then applying one of the attached geometric tolerances to the surfaces. (please see attached image)
The issue that I am having is that ProEngineer only offers "per unit length" as an option for Profile of a Surface, not "per unit area" (which is offered when creating a flatness tolerance, for example).
Is "per unit area" not an acceptable modifier to a Profile of a Surface tolerance?
Logically I think it should be allowed, but can find no explicit reference to it in ASME Y14.5 (which does mention per unit length in 8.3.2.2.).
I have seen it used in other places ( for example), but wanted to come here and solicit some other expert opinions.
Thanks in advance for any help you are able to provide!
