Jacob Cheverie
Aerospace
I have attached an image of a particular situation that I am wondering about. As can be seen, there is a profile of a surface tolerance on a small arc with respect to datum features B and A. My question is in the validity of the current dimensioning scheme.
The profile is from point X to point Y. There are basic dimensions defining the location of X, the location of Y, and the radius of the arc. The locational basic dimensions are with respect to the datum structure. In my opinion, this should be sufficient to define the tolerance zone. Is that correct?
An alternative method would be to locate the center of the arc itself with basic dimensions and assign a basic dimension to the radius. Is this method valid? If both are valid, would this method be preferred due to it's greater simplicity?
