Plastic pellets in my company sometimes build up in surge hoppers even though the rotary valves below the surge hoppers are running near maximum speed. (The rotary valves are not under-designed for this application.)
One possible root cause is that the clearance between the rotary valve housing and the rotary wheel has increased. That can be solved easily through replacement of the rotary valve.
The other possible root cause is that the pellets have static on them, which can be observed on a rotary-type classifier screen.
1) Is there any possible root causes to the product buildup in the hopper, other than those 2 mentioned above?
1) Is there any way to remove static on product pellets?
2) What process can cause static on plastic pellets?
Many Thanks
Many Thanks
