Produced water design, find the TRIM type and diameter for building 1
Ioannis Kotopoulis
Petroleum
May 16, 2019
Im on a test from my supervisor to do something like a research and i need your help. Quest is to find the line, TRIM, and ID for a tranfering produced water from A side to B side. Pa=10bar, Pb=5bar, Aheight=5m and Bheight=35m.
@gerhardl missing viscosity, spec.gravity, temperature, i found which TRIM should i use, its A4 with corrosion allowance . 250'' 150#RF, - 29/399 DEGREES CELSIUS and its sour water with wet h2s, design ansi b16.5,nace mr-01-75/78 with radiography 10% and brinell 100..i just need to know how can i assume what the ID should be and im working on the ΔP... Cause of elevation, and i cant find Δp caused of elbows...
You could find indications of the needed data by using internet search in the right way.
Inner diameter by assuming the normal velocity of the liquid in a pipeline, often more than 0,7 m/s and probably less than (say) 2 m/s. Note that for pure water 3,0 m/s and somewhat above is regarded as speed for cleaning the pipes,
Pipe bends: search for hydraulic resistance in pipe bends.
