landrover77
- Jan 16, 2004
- 40
I current run SE on a Xeon 5150 pocessor, 2Gb mem, and quatro 3450 graphics cards, with 250Gb 750rpm hard drives.
My understadning of the xeon 5150 processor is that in fact it is a dual porcessor unit, thus there are physically two processors on the mother board. This is in contrast to dual core technology which has two processors on the same board and thus one connect to the mother board. Is this correct? (When i look at my system devices it shows 2 processors of 2.66Ghz)
i'm looking at buying a new PC's, and have been told that the core 2 duo technology would be the best to go for. So is this in fact 2 spearate processors which are individually dual core?
In any case with our complex part files rebuild times after supressing a feature take a minute, checking the system CPU usage, it appears that one of the processors is maxed out and the other is hardly used. Thus i take it that predominatly SE is only capable of using a single processor and not multi threading? If so will a dual core porcessor change anything and will SE be able totake advatange of this? If so then surely as SE only uses one processor currently then the only advantage of going for core 2 Duo in contrast to core Duo is that all the background non SE activities will be done on the second processor?
I'm also planning to go up to a 4gb ram of 4*1gb, pplus a 1500rpm hard drive - all data is stored on a server.
Your thoughts most appreciated.
